Old 12-15-2021, 10:44 AM
spdbrake spdbrake is offline
Summit Racing has them for $2 cheaper @ $18.71 but charge $9.99 shipping which will bankrupt you for sure.
https://www.summitracing.com/parts/maa-29316
Or you can fab couple out of .125" X 3/4 alum angle.
https://www.homedepot.com/p/Everbilt...1717/204273996
radius on the belt sander, drill, tap and Walla! you saved $7.73 and have brackets that are much less likely to cause dissimilar metal corrosion against your distributor housing than zinc plated steel.
