Originally Posted by Hotoxide
I've tried pulling out the heater knob and even turned on the fan. even with the engine warmed up I still get cool air. Is the knob pulled out far enuf or is something else wrong?
Dave and SNAKE65 - now that I could use some heat
Look under the passenger side fender. You should see a valve installed on one of your heater hoses. By pulling the dash knob out, you should see the cable open the valve....pushing the knob, you should see the valve close.
