  #27 (permalink)
Old 12-28-2021, 06:00 PM
sunman's Avatar
sunman sunman is offline
1973 stock truck 390. Fresh air in thru small filter that clips into air filter on drivers side.
PCV in cap ( or a rubber grommet) in back of pass side with hose into carb base plate.
I’ve had other pre 78 (non emission) Ford trucks that had the same.
The Bronco is missing the air cleaner with the small filter and hose that plugs into the grommet you can see on the back of pass valve cover.
Looks like Ford did it both ways
Drivers on left side
Chaney Shores Studio
