Old 01-07-2022, 03:48 PM
Imlumpy Imlumpy is offline
Cobra Make, Engine: Antique and collectibles
I installed the same lights , they are very bright and work perfectly. My car is black so I feel a lot safer at night with the brighter lights . I can confirm you will need an appropriate flasher for led bulbs , a standard flasher does not recognize the low voltage draw and sees it as a burned out bulb and will go into rapid flash mode .
