  #45 (permalink)
Old 01-08-2022, 12:08 PM
1795's Avatar
1795 1795 is offline
Originally Posted by old willy View Post
Hey thanks Larry!
I had another thought about the transmission height issue. If anyone has a loose t10 or toploader in their shop and could take a measurement for me.
I would like to know the distance from the lower face of the transmission mount to the center line of the output shaft. If you could hold a straight edge tight against the mount and measure at the tail end that would be fine. I have the original chassis mount dimensions and I have the t-5 transmission I am using. I am lead to believe that the mount in the chassis will need to be lower for the t-5 so if I can compare the 2 measurements I should be able to figure it out. So if anyone can help me I would really appreciate it.
Thanks!
Willy,
Just saw this after sending my last post. I can take those measurements for you tomorrow and get back to you.
Jim
