  #52 (permalink)
Old 01-09-2022, 09:23 AM
MAStuart MAStuart is offline
Willy could I get a measurement from you? From the front of the rear spring tower to the back edge of the cross tube in front of the rear tower? Was just wondering if Chuck ever changed its position? On his earlier plans it was a problem.
What are your plans to mount the Lincoln center chunk. When I got started I got a Lincoln and a jag center section but ended up with a cobra one.
The Lincoln did not look to be every easy to add side mounts to and there is not much room in the rear spring tower. Looking forward to how you go about it.
Keep up the good work!
