It’s rubbing because the caliper needs to be pushed toward rear of car, so push caliper up and away from the disc, no bar or spring up top, now push the bottom of caliper away from disc toward rear of car, now you will have just enough room on the bottom of caliper to insert bar and spring mated to each other in on an angle then tap it home.
