Originally Posted by spdbrake
On your Speedo lag on startup. It sounds like it has a GPS input. The lag is normal if you're equipped with one.
On the Coolant temp reading "incorrectly". What are the readings? Is it a C or F gauge?
Yeah I was unaware but that is exactly what it is, GPS takes a second to start picking up sats.
As far as the temp it never gets over 155 (which I believe is wrong) but my handheld temp reader reads the same in F*. 155 is about where the auto fan cuts on aswell. Really hard to believe this thing is running that low. reading on the head idling is about the same few degrees higher, same w lower hose. I guess it is what it is but pretty sure my hand held is on point.
