The alternator makes as many amps as the system needs, up to whatever it's rated at. If you're drawing a lot of power - electric pumps, EFI, fans, etc - then it will produce amps enough to feed them all. Look at all the things that are running, and add them up. See if it's pretty close. If not, you've got an unknown amp draw somewhere.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
