Old 02-12-2022, 05:39 PM
Soundkillr Soundkillr is offline
Cobra Make, Engine: Backdraft cobra FE big bock
Originally Posted by Sledge View Post
I installed the Active Autowerke diff support in 2010 and have not had a problem with broken rear end parts...at least not yet!
Was the install easy? Does the lower cradle plate have threads in it for the two bolts to sandwich it down? Im trying to fgiure out how the two lower bolts attach.....and I would assume the upper cradle plate is threaded...
I see no bolt holes in the front carrier to accommodate the two bolts in the kit.
