Originally Posted by 169mph
I had the same thing happened last month. Same Bolt sheared. I’m trying unsuccessfully to extract the end of the bolt out without dropping the differential. Tried to use a dremel tool to cut a groove in the end of the bolt so I could back it out with a flat head. Couldn’t cut a groove deep enough. I think lm going to drop the differential and replace the bushings and upgrade the front bolt.
Thanks Mike
So heres the method im going to try and follow...
https://youtu.be/-8N0y0jVAng
Fast forward to the five minute mark to see what im trying.
