Originally Posted by jbmatth
I debated this as well, but couldn't find a better place for it, if you go by cubic inches it would be better placed in big block. However, an aftermarket SBF block was developed to 460 in^3, and some big block Mopars were under 400. I therefore decided to base it off of bore spacing:
SBF 4.38"
SBC 4.4"
Godzilla 4.53"
BBC 4.84"
BBF 4.9"
So based on bore spacing the Godzilla is closer to small blocks than big blocks, thus I chose Small Block Talk. Is there a better place for it, I'm all ears, I haven't frequented this forum for many years but wanted to share what I've done to answer some questions for others.
JB
That is GM/Mopar thinking,, clueless supermarket Hotrod/Car Craft drivel, big block vs small block. Ford has always had at least 3 block sizes, small, medium, and large.
The Godzilla is just a modern FE, with slightly smaller bore spacing.
Can you imagine the BILLIONS of dollars Ford could have saved by just continuing production and updating of the FE instead of re-creating it decades later? You can easily buy the components for a 445 FE today.
https://www.motortrend.com/how-to/md...-block-engine/
