Hydraulic throw out bearing
I posted this on the CCX forum. I recently changed my clutch set up from a10 1/2 inch set up and an aluminum flywheel to a billet steel flywheel and a 12 inch clutch. The issue I'm having is when I changed everything a can't get the car in gear, I pulled everything apart checked to make sure I had the clutch installed correctly (I did) and rechecked the gap for the hydraulic throwout bearing-which was correct-put it all back together and still can't get the car in gear.
New parts are as follows, new bronze pilot bearing, 12" pressure plate and clutch, billet steel flywheel, the only part that wasn't replaced is the throwout bearing,
I attached a picture of the type of pressure plate I'm using (the picture is of a 10 1/2" plate same type only 12"). Hopefully someone else may have had this situation and was able to resolve it.
BTW the throwout bearing is the old style Tilton 600 (1997)
