Old 03-14-2022, 10:41 AM
MISFIT 1 MISFIT 1 is offline
Default Electrical issues
I have been chasing electrical issues the past week. Below is what is going on:
10 VOLTS ON VOLT GAUGE, 12+ AT ALTERNATOR
TURN SIGNAL CAUSE THE TACH TO JUMP UP AND DOWN
HEAD LIGHT ONLY WORK IF I HOLD THE HIGH BEAM BUTTON
ANYTHING ELECTRICAL CAUSES THE VOLTS TO DROP IE FANS, FUEL PUMP, ETC
I WAS THINKING BAD GROUND. SO FAR I HAVE FOUND GROUNDS AT FRONT PASS SIDE FRAME, UNDER PASS SIDE DASH, PASS SIDE FLOOR, MOTOR GROUND AND THE BATTERY.
ANY HELP IS APPRICIATED
