Wilwood clutch reservoir leak?????
I have a slow leak that I believe I might have narrowed down to the reservoir up on the firewall. I tried tightening both the hose clamp and the big clamp on the main body, but that had zero effect. Anyone run onto this one??? Wondering if the reservoir is prone to cracking or some other way for it to leak. I guess my next move is to remove it and take the hose and big clamp off and do a good inspection before I order a new one. Cant really see any issues with it mounted and I will buy a new one no problem, but I would like to be sure it is getting fixed. Nothing worse than spending a bunch of time and effort on a leak only to find out that you didn't change a thing!!! Thanks in advance for any info fellas, it is greatly appreciated!!!!
