Old 04-01-2022, 06:19 AM
Alfa02's Avatar
Alfa02 Alfa02 is offline
Gold Star Contributor
As Bill S. said a 20ft one is just right for a Cobra. 3' on each end makes loading & unloading a pleasure. I brought 2018 20' Interstate super coach (Workmanship is top notch), with driver door, 4' side door, rubber floors, solar panels, and E-track, steel frame with Alum sides, 4100lbs empty, 6500-7000 loaded, make sure you get Torsen-bar axles (3500-5200lbs per axle) with replaceable hubs, the ride & safety are well worth the extra cost. a 16 Suburban should pull it nicely.
