Easiest way to tell is put some sticky tires on the back, use a heavy flywheel, bring the launch RPM up to 6500 or so and side step the clutch. After a few launches like this you will either have parts under the car or not. If you don't then the transmission is pretty good, at least good enough for what you intend to use it for.
