04-03-2022, 09:54 PM
SK
Originally Posted by tpatodd
Hi all-
Exposing myself here in a moment of embarrassment but need some guidance.
Changed my oil yesterday and did not notice the old oil filter gasket stuck. Fired up the engine..... ~4.5 qts out in about 7 seconds. Good times.
Other than the massive cleanup on the floor. Anything under the hood I should be concerned with?
Oil got on pretty much everything on the front of the motor: belts, hoses etc.
Oil shot through the front rims so I am assuming on the back of the brake rotors, etc. I have not pushed the brake pedal so hoping it did not get on the pads. Might have.
What would the pro's do in this situation for clean up and pre-firing her back up. (yes, I have resolved the oil filter issue and filler her back up with oil).
Thanks 1,000,000
That almost happened to me. I was wondering what was different about installing the replacement filter when I realized the double gasket issue. Glad I found it before I experienced what you did!
Brian
