After posting I had to go look at mine. I have the cobra rear mounted with no guts in the case. It looks like the pinion has a bunch of up angle also. I was wondering my pinion was going to clear. On the floor I have a Jag and a 8.8. I also have some 9 inch fords about cutting down and making independent. I was going to see if I could make it so it had plug in axles like the 8.8. I might also look into seeing if I can make a front mount that would bolt into the original cobra front mount.
Any chance you could take a picture from the side. I want to see how the axles align with the side holes?
You are making me want to work on mine!
