Originally Posted by eschaider
While I am unfamiliar with the particular EPEC system you purchased from Ford, virtually every aftermarket system will allow you to specify the firing order of your choice. The only caveat is that you need to have a cam ground to support the firing order and in the case of flat plane crankshafts you also need to have the correct crankshaft.
EPEC kit includes an A9P ECM and control software....
