  #30 (permalink)
Old 04-18-2022, 05:46 PM
Mike_Gr Mike_Gr is offline
Originally Posted by spdbrake View Post
I looks like a great setup and I'm sure Jay's shop did a great job. Can you share the cost for the mod and IF it is a one-off customer mod or can it done in a home garage a-la quasi kit form? Thanks.
Vintage has done this upgrade on two cars I am aware of. Mine was the first and then they did it on BDR #1802 that just sold at Barratt Jackson recently. You could do it in your garage if you are handy with a welder as the front bracket needs to be welded to the subframe and then the rear hub spacers would need to be milled to work. I don't recall overall cost but was likely around 5k. Would need to buy an e32 diff., mine came from diffs online. I went with a Quafe LSD with 3.64 gears. This is a kit marketed to the 3 series BMW crowd.
