Old 04-19-2022, 02:10 AM
Daytona Dek's Avatar
Daytona Dek Daytona Dek is offline
Cobra Make, Engine: Shell Valley Daytona, Ford 302
Originally Posted by krausewich View Post
Hi Dek,
Use a seal on the door and on the body to make up for irregularities. The two pressing together should get you a good seal and allow enough compression to get that door shut. Use two different sizes if you need to..
Thanks for your reply. Whilst waiting for one I’d came to the same conclusion (more or less). Although I’m not a fan of adhesive seals the bottom and front edges are largely hidden on the door. Another advantage is if necessary I can cut it short where the gap is very small and it won’t be visible. I think I’ll just put some finishing trim (not weather seal) around the door aperture.
Dek
