Front works fine, yes the bushings are a little angled . no binding and no noise. Everything lines up otherwise. This is the way it came to me. If I was going to redo it, I would have the plate cut off and an angled plate welded in. To redo the front at this point would be a total upfit. Current setup is QA1 coilovers with proper springs for the Mustang II upper mount. the red eibach springs were not used, went with the springs that came with the coilovers.
