Thread: Torque Specs
Old 04-25-2022, 09:46 AM
cycleguy55's Avatar
Originally Posted by Phoenixjeff View Post
Good Morning Cobra Builders,
I am new to the site and new to building my first and hopefully not my last Cobra Replica (1967).
Question: Where do you all locate Torque Specs? Specifically in this case for Caliper Brackets, Slide Bolts, and Banjo Bolts for brake line attachment?
Many thanks for any and all help!
The Calipers are from Speedway Motors "910-31040" 2 3/4" Big Bore Brake Caliper fits 1978-88 Metric.
If you can't find the GM specs for those calipers you might try the Wilwood instructions for their calipers that replace those in GM installations. Slide pin bolts are torqued to 35 ft-lbs. Banjo bolts are 96-120 in-lbs.
https://www.wilwood.com/PDF/DataSheets/ds842.pdf
Brian
