Old 04-30-2022, 02:50 PM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Default Horn Relay part number
Suspension and brakes passed my tech inspection
All fluids flushed except rear differential at this time
No drips or leaks
Brake light issue solved (funky LED's previously in all four corners, not enough draw to trigger the brake lights, back to HiPo 1157's for now)
Tightened all loose bolts (expect for those rattling around in my head), just down to the horn, where I believe the relay has gone bad. From what I can see, the car currently has a Bosch 0332209138 relay installed.
Is this the correct part number for the horn relay?
Is this also the same part number for the other relay on the firewall to the right of the main harness grommet?
Thanks in advance,
Bill S.
