Old 05-12-2022, 03:25 AM
Bill Kesner's Avatar
Bill Kesner Bill Kesner is offline
Cobra Make, Engine: CSX4141
Hey Oliver,
I purchased a set of Wilwoods, but you'll find the fitting don't match up as they are backwards compared to the AFCO's. Also had bore size issues that Wilwood only makes, and I wanted the same ratio Shelby set up on mine.
You'll find the Tilton 76 Series a better fit, especially for your hard lines and bore sizes. On the Tilton's, the end is plugged, so I moved the plug to the center. Very front is your inlet, and the rear is your outlet. My front Master is 3/4, and the rear is 7/8. Hope this helps! If you send me your email, I'll send you some pics.
- Bill -
