  #23 (permalink)
Old 05-23-2022, 04:14 PM
FlyingGumby's Avatar
FlyingGumby FlyingGumby is offline
Cobra Make, Engine: BDR #870 Salsa Red w/White stripes Roushcharged 4.6L 3V
The trailing arm mount bolts look over torqued. The drivers side didn't break but is surely weak. Do alignment shops know to torque only these nuts to ~18 ft-lb (based on the bolt spec site spdbrake shared)? Consider adding a bolt check to your maintenance routine.
My outer CV boots are torn and need replacement so off came the axles. One of the axle/spindle bolts required a pipe for leverage to remove. The other came off with a standard 1/2" ratchet. I estimate the torque on that one to be ~40-50 ft-lb. Spec is closer to 214 ft-lb. Consider checking these bolts too.
The diff is a little oily and leaves an occasional drop. Might as well replace 1 or more seals while everything is apart.
Will also replace the spring pads, trailing arm and control arm bushings, and add adjustable camber arms. Just need to decide which ones.
