Old 05-25-2022, 06:13 AM
DanEC's Avatar
DanEC DanEC is online now
i doubt omitting the gasket creates any issues since as you said it’s very thin. I put two gaskets on mine and it was fine. There should be lube getting through the Rear bearing unless somehow a sealed bearing was installed. I would suspect something amiss with the speedometer gear adaptor.
ERA 782 Running
