Originally Posted by ERA174
I believe the only way for lube to reach the output shaft housing is thru the roller bearing. I suspect the proper speedometer gears, once installed were destroyed by the lack of sufficient lube.
After thinking about this "lack of lube" thing, it makes perfect sense and it sure seems like the gears would need some lube. But......the fact is, after I changed the output shaft "drive" gear I did in fact fill the gearbox with 90w gear
oil, so while I will buy it for the first set of gears, I know I had plenty this last time and it still wasted them.....nothing is ever simple!!!!! M
