Originally Posted by Mike_Gr
While the trailing arm is out can also consider replacing trailing arm bushing. This is a weak spot in these cars keeping the rear end planted. I had this bushing replaced with a monoball I did subframe bushings at the same time so hard to tell how much each contributed to improvements.
Subframe and diff came out easily.
Going the monoball route for RTAB. What poly diff carrier bushings are recommended these days. Choices seem limited with 14mm front carrier bolt. Or, just drill the a 12mm bushing sleeve to accommodate 14mm bolt?
Saw on another thread that you did a major upgrade after using a DSB. I don't want to go that far but do you recommend a DSB? Is your used one still available.
Thanks.
