"gears need to be lubed upon installation"......this could be the problem. Admittedly, I just put them in and didn't really consider any need to pre-lube. I am wondering if this equalizer hole {for lack of a better term} is even open on my transmission......I will find out when the new gears get here. I did in fact get a new cable and I found Ford OEM gears. Gears are on the way as well as the tail housing gasket. Thanks again John!!!!! M
