Info:
Our tank fits very close to the trunk floor. The normal sender sits in a well (1/2" deep x 3" diam.) so that it doesn't extend higher than the plane of the tank top.
If the top of the pump assembly is larger than 3", it will have to be mounted on the top of the tank and trunk floor modified to accommodate it. Otherwise, we can probably weld in another well for the pump, although that pump looks too high to fit in the well.
