Old 05-27-2022, 05:44 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by msinc View Post
"speedometer gear adapter"??? Can you clarify what you are calling an adapter please sir??? I am not familiar with what that is. I will definitely inspect that bearing...it would be just like my luck to have had some idiot install a shielded or sealed bearing in place of the correct open one!!!! Thanks for the info!!!! M
Maybe adaptor is a bad term. The fitting on the transmission end of the cable the driven gear fits into and is inserted into the side of the tail housing over the drive gear.
ERA 782 Running
