I used the 1" at a 45* angle up and left with a couple machined washers to space the shifter a little more left. I used the 1" because I had already cut the tunnel cover tor the standard Tremic shifter and the boot would not cover the hole with the 3". I will probably order another tunnel cover from ERA and install the 3" as it puts the shifter in exactly the original position on the ERA FIA.
