11. Pit Settings
a. Tires set at cold pressure, the end results is to have the tires come off the track at 30#lbs. So we would set the tires all at 25#lbs. cold and see what they are when they come in, again, 30#lbs is optimal, when they come in we will read the pressure and then lower the cold pressure going out for the next session.
b. Be sure to have the Tire Pyrometer, and the Tire Pressure gauge.
c. Pad to record the tire data and get the temps and pressures of the car when it comes in.
