  #22 (permalink)
Old 06-15-2022, 07:24 PM
FlyingGumby's Avatar
FlyingGumby FlyingGumby is offline
Cobra Make, Engine: BDR #870 Salsa Red w/White stripes Roushcharged 4.6L 3V
Originally Posted by SBSerpent View Post
But you were able to do it judging from the photo of the rear spring and the damaged pads that you show a few posts back....
Putting my BDR back together after bracket fix and bushings. Discovered that I was not able to reinstall my rear beehive spring without the front of the rear trailing arm bracket loose/unbolted. Trailing arm downward angle and travel is limited while the RTAB bracket is bolted. The beehive is somewhat compressed when installed. No way around it on my car. Others may be different.
