The flasher unit is unlikely to affect the brake lights - the most likely problem (if not bad lamps) is a loose connection or earth in the system, check with a voltmeter when brake pedal depressed - if connections are good then the next most likely problem is with the switch which is either mechanical or hydraulic. again check for continuity of circuit when pedal depressed.
