Old 07-04-2022, 07:34 PM
frankym frankym is offline
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
Default 4 way flashers for ERA 575
Looking to build on my success fabricating a mechanical backup switch - I put a switch and LED light on dash and would like to add a separate hazard flasher relay and tap into each corner light feed. My research suggests if I provide power to the switch and then to the new flasher relay, i can tap into each marker lamp with a “diode” to make the current move one direction only so that the directional switch continues to work selectively and same for brake lights. Anybody done this using the same method? If anyone can share the ERA wiring diagram that would be awesome. Btw I met some great folks today at the Essex CT car show. There were 6 cobras there. 5 ERAs and 1 Backdraft.
