Originally Posted by bobcowan
If the engine is moving enough to damage the tank, it's putting stress on other areas as well. You've only discovered the weakest link. When you fix that, you'll find the next one.
I would install solid motor mounts. Cheaper. Easier. Fixes everything
I have an aluminum block. With solid motor mounts, would the be a danger of stripping the motor mount threads in the block? My engine dynoed at 660 lb-ft…
