Old 07-12-2022, 11:42 AM
strictlypersonl strictlypersonl is offline
Bob,
I'm thinking the return would need to be placed higher up so that the fluid was not under any pressure when returning to the tank. Clearly, I'm not expect when it comes to anything fuel injected, but I believe my thinking in this case is sound.
Bill S.
As long as the return line is below the fuel level, even if the outlet is higher than the fuel, there is reverse pressure against the returning fuel. But, compared with a fuel injection's base pressure, that pressure head is irrelevant. Bottom Line: The fuel can be returned at any location into the tank.
