When you have that particular windage tray between the crank and the pan, it goes a long way to help in limiting the amount of
oil the crank can whip up from the pan. if your six or seven quart fill takes you a bit over the baffle in the pan it probably doesn't matter much. When the engine is running, that black plastic windage does a pretty good job of protecting the
oil in the pan.
