Old 07-23-2022, 09:35 AM
EsFors EsFors is offline
Cobra Make, Engine: Backdraft RT3B, Roush 427R
Default Caster Solutions?
Looking for a bit of knowledge on solutions to fix a caster issue. Tried to get #1183 aligned last week and everything came back good but the front drivers side caster at +4.4. This should be closer to +6.2. Thankfully this is only resulting in a slight pull to the left but I want to tackle it asap.
I’ve read through many threads but I don’t see a real definitive solution. Camber/caster plates don’t seem to have enough travel to accommodate more than small adjustments so it looks like replacing the CA mounts with adjustables may be the ticket. Something like these:
https://www.garagistic.com/products/...EaAndTEALw_wcB
https://www.akgmotorsport.com/produc...IaAkjDEALw_wcB
I found 3 or 4 different mfr’s with similar parts. Anyone have some experience or recommendations?
