You may know that you can change front camber by raising / lowering corners with the spring collars. Consider raising the right and lowering the left to get matching cambers.
Adjusted my front cambers with shims rather than collars to avoid messing up ride heights and corner balancing. Front is currently -1.8. Will install camber plates if more is needed.
Good luck.
