Originally Posted by jhv48
If your spf is like mine, you already have a remote starter solenoid on the passenger side firewall.
Your symptoms mirror a dying battery.
Or a bad ground, or a bad engine to chassis ground, or a bad starter solenoid, or a bad battery. In that order
Bill S.
PS: Does the OP have a 1 wire alternator installed? If so, perhaps the diodes have gone bad within, even showing a charge on the gauge, this too could be the root cause, as I found out this past weekend.
