Old 08-13-2022, 06:10 AM
strictlypersonl strictlypersonl is offline
Originally Posted by GavCob View Post
Hi,
Thanks for picture
Any closer pics of linkages? You gone straight to outer fulcrum bolt?
Regards
Gav
That's a leading arm design. It looks like they replaced the lower pivot pin with one that has a clevis mounting end. If you are using a trailing arm, you should be able to use the normal trailing arm bracket on the LCA. (In fact, if they had switched their arms from side to side, they could have done that too.)
