Old 08-13-2022, 09:45 PM
eschaider's Avatar
If you look at the front of the engine, all the cam drive, oil pump. water pump and other accessory drive hardware is missing. Additinally there is no crank snout or flywheel flange visible which probably means the entire rotating assembly is missing. I suspect it is a block, heads and headers. It would be a good bet the heads are empty castings.
Stil in all, a very impressive coffee table...
