Originally Posted by tims210
What sensors should I be focusing on? Wouldn't a faulty sensor throw a fault code which I am not seeing?
Every one, there are only a half dozen or so and you already know you have a problem with cam phasing so you ought to go to the commanded vs reported cam phasing as a starting point.
Be sure to check your OBD II error codes if any are present. They can save a lot of uninformed stumbling around looking for a problem.
