Old 08-30-2022, 02:38 PM
spdbrake spdbrake is offline
From what you've described you have a CCW water pump with a tensioner, Billet brackets and the belt is walking off the crank pulley.
Would be great if you can post a pic or two. The are several configurations, and even more if you have power steering.
But I'd check the tensioner 1st as it is grooved usually (see pics request) to see if there is any wobble/play in the bearing or mount arm. If it leans it will walk your belt right off.
Also check all the attaching hardware for tightness.
