Old 09-04-2022, 04:30 PM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
The spots are caused by the mold release agent bleeding through the letters. You will not be able to get rid of it by cleaning. The tires needed to be properly prepared by shaving the tire down past the rubber that has the release agent in it, then applying the letters. It is not an easy process to do correctly, you could spend a couple of hours or more shaving one tire but you will not get any bleed through.
