Low on power?
I can blast off in second gear hold the brake lightly and only burn about 30 then grabs and goes, I hear some can just jab it in 3rd and break them loose, I am lucky to jab it in 1st and break loose if its cooler out. FE 428 10:1 780 Holley vac sec open 3/4-7/8 with the lightest spring ,tall oval air cleaner, RPM performer, edelbrock heads, 36 total timing, hyd. Cam .539 280 ,at .050 230 lobe sep 110. 350 gears 29 x12 MT S/R tire, WR toploader. Runs great I just feel I am leaving some on the table, may try to get some Dyno and tune time. The tubes in side pipes are rather small, I guess that would be a good and cheap place to start? Any feed back would be much appreciated.
